wheel / hub cap fitment issue Hello guys,
My guess is I have either the wrong wheels or the wrong hub caps... 1931. The ID of the wheel where the cap will be placed is 3 3/4". The OD of the hubcaps I have is 4 1/8". The distance from one bent tab to the one opposite is 3 1/4". Kind of a BB in a boxcar. So, what say you? Thanks. |
Re: wheel / hub cap fitment issue I think the larger hub caps fit the early V8
Re: wheel / hub cap fitment issue Can you post some pictures?
Re: wheel / hub cap fitment issue Wrong hub caps.
Re: wheel / hub cap fitment issue Quote:
Re: wheel / hub cap fitment issue Photos would help. The Model A hub cap can be hard to put on and require the tabs to be bent in a little. That may be the problem.
Re: wheel / hub cap fitment issue What size are the rims? 21"? 19"? 18"? 17" 16"? Or?
