Timing gear cover I have to repair the timing gear cover on my 1930 Tudor (plugging a hole).Is the metal cast iron or forged steel? This will help me to decide if I should TIG weld it or braze it.
Re: Timing gear cover The texture looks like cast iron to me.
Re: Timing gear cover It would be cast iron.
Welding/Brazing might make an issue with "warpage." You might "flatten" it after the fact with sandpaper glued to a tablesaw table. JB weld might be a better fix but you have to "grind" the surface to make a place for the epoxy to "grab hold." Actually I've seen a perfectly good cover on Ebay for $8. I bought it because I saw it was actually a "Model B" cover which I wanted for use with a Gordon-Smith Air Compressor conversion - which uses a Model B centrifugal distributor to match the "load-no load" condition of a compressor engine. (cover/timing pin and Model B distributor have to be used as a pair to allow "normal" engine timing.) Ebay: $14.88 plus ship best price currently. To tell the differences between covers, see Vince Falter's page on the covers. The page doesn't seem available at this moment - perhaps Vince is working on the site? www.fordgarage.com Joe K |
Re: Timing gear cover Quote:
I'll be using JB weld. Thanks for the reply Joe |
Re: Timing gear cover How did it crack...and there is a spring assembly that rides on that thing. Maybe you should try to find another one. Are you sure you want to try to fix that one?
Re: Timing gear cover The small differences between covers are shown at https://www.fordgarage.com/pages/timingcovers.htm
Joe K |
Re: Timing gear cover I would think it would be easier to find another one. Temporarily thread the hole (maybe enlarge it) and put a bolt/plug in.
Charlie Stephens |
Joe K |
Re: Timing gear cover Go get another cover. Don't waste your time welding, brazing, or yuck puckying with JB Weld. These are all band aids.
Re: Timing gear cover Just get another cover. they are plentiful and don't usually cost much. Save you some work.
