Antenna Cable Would anyone know where I could find an antenna cable that attaches to the chicken wire in the roof of my 36 3 window coupe? Or how to make one. The roof panel of my car is missing so I'm going to have to make a new antenna.
Re: Antenna Cable 2 Attachment(s)
Rocky, the antenna cable is a shielded cable with the inner cable attaching to the chicken wire and the braided shielding cable being grounded to the chassis. Here are some images that might help.
Re: Antenna Cable Quote:
https://www.fordbarn.com/forum/attac...4&d=1694883388 |
Re: Antenna Cable I got a spare tire lead to make the running board antenna lead in from Tyree Harris , i suspect he would make the roof one too
Re: Antenna Cable Great! Thank you everyone.
Re: Antenna Cable If you are handy and can scrounge some RG58/U coax from a local ham, it will work fine.
It is not the exact same impedance as the original but WILL work for AM broadcast use. Been there, done it. |
Re: Antenna Cable Third Gen Automotive has the radio antenna wire with the connector to the radio, but it does not have the braided coaxial shield which could mean a change to include the shield as has been suggested by Pete.
Re: Antenna Cable I just ordered one. Thanks
