1/2 - 20 repair fitting I need a source or pt # for the repair fittings that I find in core carbs that
find their way into my stash. The male end has 1/2-20 threads and seals with a gasket against the inlet . The female end accepts 1/4 tube , ferrule and 1/2-20 Ford nut. I use these fittings to salvage 94 air horns where the ferrule seat is no longer concentric enough to be leak proof. I'm running low ! Charlie ny |
Re: 1/2 - 20 repair fitting Charlie, is this what you need? I’m not sure if the inlet side of this one is made for a Fordnut or flared line. Worth a look.
https://www.carburetor-parts.com/Bra...80_p_2408.html Joe |
Re: 1/2 - 20 repair fitting HB,
I'll give mike a jingle and see if he has them for Ford nut....the inlet on the one in photo is for flared. Thanks, Charlie |
Re: 1/2 - 20 repair fitting Deleted
Re: 1/2 - 20 repair fitting Quote:
Sal |
Re: 1/2 - 20 repair fitting Michael.......
Don't go too far...do you have any ?.....Mike's came up dry. Charlie ny |
Re: 1/2 - 20 repair fitting I am thinking that Max had (or has) this sort of stuff. Try Max?
Post #2 seems to have what I think you are asking. |
Re: 1/2 - 20 repair fitting Weatherhead 59X4 look them up on the internet.
Re: 1/2 - 20 repair fitting 1/2-20x8an fuel inlet adapter fitting, quadrajet parts.com
kurt |
Re: 1/2 - 20 repair fitting 2 Attachment(s)
https://www.vintageford.com/global_s...0507&Category=
FUEL LINE BRASS FITTING WITH FERRULE 1/2 INCH HEAD 1/2-20 FUEL LINE BRASS FITTING LARGER 9/16 INCH HEAD 1/2-20unf |
Re: 1/2 - 20 repair fitting For 1/4" line...
Re: 1/2 - 20 repair fitting Charlie I deleted my comment as I had a solution that had apparently dried up… I have none. Check with James at Gotham auto parts.
Re: 1/2 - 20 repair fitting Same as a model A fuel line. Brattons antique auto has them...or did
Charlie isn’t looking for the fittings shown they are readily available, heck we even have made them for the model a vendors. |
Re: 1/2 - 20 repair fitting Charlie I can get them but they are for a flared line not a ferulle
Re: 1/2 - 20 repair fitting Michael....thanks.
Charlie ny |
Re: 1/2 - 20 repair fitting What would it take to take one of the available flair fittings and remachine the seat to take a 1/4 pipe ferrule?
If there was a way to do that, there would be a way to repair the seats in the carburetors and fuel pumps as well. |
Re: 1/2 - 20 repair fitting Weatherhead went to Eaton. They may have manufactured stuff like that back in the day. A person would have to an old catalog to find out. If there is a part number then a person may be able to find them.
Re: 1/2 - 20 repair fitting Mart,
I'm working on it now...to keep 100% concentricity between the seat and threads is more than plunging a countersink into the flare contour. Charlie ny |
