flathead engine 1941 what years of flathead bolt right in?
what are mods necessary to make other years to fit 41? thank you. |
Re: flathead engine 1941 http://www.vanpeltsales.com/FH_web/f...ifications.htm
See above 38-48 will bolt in using your water pumps, fan, intake, distributor. 49-53 will work, mostly fan issues and rad hose hookup. It all depends how much work your willing to do and what outcome you want. Stock,custom,high performance, it's up to you. |
Re: flathead engine 1941 Any 59a block would be a good fit, but so would other years.
Re: flathead engine 1941 looking for simple and stock.
looks like most will fit? how about truck engines or 60 hp? |
Re: flathead engine 1941 ronn:
Suggest you do a lot more research about the differences between the various flat head Ford engines BEFORE you do anything else. For instance: Installing a 60 HP engine would greatly under power your 41 and be a huge mistake. |
Re: flathead engine 1941 You said "flathead and didn't specify how many cylinders. There are a lot of people who consider the "G" and "H" 6 cylinder engines to be superior to the V8's. Since the first 6 came in '41, they are also a possibility. Parts are more difficult to come by than the more popular V* models, however.
Re: flathead engine 1941 Quote:
Are you looking for a complete engine that is a bolt in? A short block that will work? A bare block to build up? The original engine was most likely what is referred to as a "raised" intake surface block. There are very few years with that feature, mainly 41. When you get into the V8-60 and the 6-cyl engines I think you would have transmission/bellhousing issues, maybe radiator issues. |
Re: flathead engine 1941 Yes J, looking for a complete engine to just bolt in. so will stay away from the 60s and 6 cylinder then.
thank you all. |
Re: flathead engine 1941 I would think any of the 59a engines (46-48) would be a fairly simple install. A 41 or war year engine would be a good option but probably not many of them out there.
Does anyone know what the oil pan variations are between the 41 cars and the later 59a car and/or pickup-truck engines? |
Re: flathead engine 1941 PM sent
Re: flathead engine 1941 I believe 3 engines were available for 1941, 4, 6, and v8.
Only year as far as I know. Bruce |
Re: flathead engine 1941 ok and how about a 1934?
I have a lead on a couple that I can drive to. |
Re: flathead engine 1941 did not Tom- where is it listed?
thanks |
Re: flathead engine 1941 yes and simply why?
Re: flathead engine 1941 They are a lot more expensive to rebuild, because of the babbit main bearings and different rod bearings also the water pumps are in the head so, it complicates the installation.
Re: flathead engine 1941 2 Attachment(s)
yep the V8 bell is different than the 6 |
Re: flathead engine 1941 I bought a 41 convertible about three months ago and a 41 woody about a month ago- for no apparent reason on the year.
both have the trans and no motor, so yes want to bolt in complete engines for ease and wont be putting crazy mileage on them, so just decent running engines. dont know much about flatheads, but you guys are teaching me. mostly have messed with model A's. |
