Reversed generator output post Is a generator that has the output post mounted on the front of the generator, so that the cutout relay is 'backwards' (wire connections are made on the side towards the firewall of the car not the radiator side) a Model A generator? Is it an Autolite gennie?
Why was that done? I see it on more and more Model A Fords. Looks 'weird'. I know it still works fine just curious where that came from. |
Re: Reversed generator output post Most also had the rear ball bearing, 29-30 --- look in the judging standards, the parts got changed around a lot by rebuilding
Re: Reversed generator output post The one with the stud in the front was used from October 1928 through March 1930,
the one with the stud towards the rear was used from March 1930 through the end of production. Bob |
Re: Reversed generator output post Similar to Model T used from 1919 to 1927 re hook up.
Re: Reversed generator output post Thanks.
