32 Roadster mirror Does anyone have a photo of an orginal roadster rear view mirror that goes on windsheild I need to know where it mounted and the bolt spacing,someone has changed mine and drilled holes and I want to know which holes to use? I also need a mirror if someone has a good extra one.
Thanks |
Re: 32 Roadster mirror I would suggest you use "the Swap Meet" located at the top of the page in the (Red Ribbon) an place an add there for the 1932 Ford mirror.
You should have better luck. Mark |
Re: 32 Roadster mirror 1 Attachment(s)
Wait until you find the bracket. Put it in the middle of the frame and drill the two holes. Mine are 2 5/16 on center. I would wait until I found the bracket before I drilled anything.
Charlie Stephens |
Re: 32 Roadster mirror Thanks Charlie
Re: 32 Roadster mirror At one time and hopefully still, Vintique offered a perfect reproduction of the '32 standard phaeton/roadster mirror bracket right down to the 2 5/16" threaded hole spacing.
Re: 32 Roadster mirror Quote:
