Adjustable Drag Link I was taking apart a front end assembly today and came across an interesting drag link. It looked like one end was cut off and one of the ends from a tie rod was threaded on. This would make the drag link adjustable for length. I have not seen anything like this before or in the restoration books.
Ten or 15 years ago I purchased a couple of adjustable drag links that had a turnbuckle arrangement in the middle so you could adjust the length and center the steering wheel. I have not seen them in the catalogs recently. Has anyone else seen one of these drag links with one end that has a tie rod end threaded on? Thanks, Vic |
Re: Adjustable Drag Link Seen? I've made a few like that.
Re: Adjustable Drag Link A couple years ago an article about how to make one by Wiley Higgins (sp) was in the MAFCA newsletter
This is what I could find http://modelafordclub.co.nz/wp-conte...Box-Aug-11.pdf .. |
Re: Adjustable Drag Link Joop:
Thanks for the article. Vic |
Re: Adjustable Drag Link Will this work if using a shorten pitman arm?
Re: Adjustable Drag Link TDO:
It definitely will. Vic |
Re: Adjustable Drag Link I made one for my car using a stock drag link, cut and threaded it (one end LH and the other RH) and used the sleeve from a GMC pickup. I threaded the LH end in the lathe before I cut it in half. I also have a shortened pitman arm.
Re: Adjustable Drag Link When I was young I decided to try and cut some left hand threads. After about a day and half I finally figured it out. I was so frustrated I was even working between the wall and lathe and my grandfather would walk by and start laughing. I know, its actually easy once you figure it out. But, until then,,,,,,
I had kind of a similar experience learning to weld. I don't need no stinking helmet ! Ever have a doctor peel your eyes like an onion ? |
Re: Adjustable Drag Link They are not only adjustable for length but can be used for Right hand drive cars OR left hand drive - Do any of our usual suppliers still make them?
Re: Adjustable Drag Link Quote:
Re: Adjustable Drag Link 1 Attachment(s)
John, --- the last supplier here that had them was Sacramento Vintage Ford, they have now discontinued them, they sold for $160 --- I made mine using a used draglink, and this coupler, if you want it I have a spare I could bring home in Sept, probably cost a few pints --- LOL.
Regards Brian. |
Re: Adjustable Drag Link 2 Attachment(s)
Re: Adjustable Drag Link Joop,
Thanks for the link to the drag link article. |
I production welded my way thru college. Got many a sunburn. Plus whenever it rained the shop flooded, your hair would stand right up straight. |
Re: Adjustable Drag Link An outfit called Auto Care and Restoration in Redding California used to sell one for $48 exchange about 20 years ago.
Re: Adjustable Drag Link I remember seeing a couple of adjustable drag links in the Swap Meet section.
Re: Adjustable Drag Link See "Machine Girls" entry number 12
I bought one of these when the shortened pitman arm resulted in full lock one way and not the other. Being able to adjust the length of the drag link solved the problem. It's a quality product Keith |
