What does YOUR timing gear look like? 1 Attachment(s)
Tourer is in for a Stipe .330 lift cam. Guess we'll add a bronze timing gear from Dan.
This laminated fiber gear (not the super crappy macerated type) has only 5K on it. Three teeth show the same amount of tooth missing. Might wanna be thinking aluminum or bronze next time..... |
Re: What does YOUR timing gear look like? Dan is back in production now. I just bought a bronze cam gear and a steel, heat-treated crank gear from him.
Re: What does YOUR timing gear look like? Quote:
Re: What does YOUR timing gear look like? Dan: the finest workmanship I have ever seen...well, Bill Stipe's workmanship is flawless, also
Re: What does YOUR timing gear look like? I like that ! LOL
Re: What does YOUR timing gear look like? Cool clock !!! Did you make it ?
Re: What does YOUR timing gear look like? I think it's always prudent to replace both gears at the same time,a slightly rough crank gear will chew up the cam gear in short order.
What is your opinion why the teeth are damaged in only 5k miles? |
Re: What does YOUR timing gear look like? I have the same question as Brent, plus, was it making any noise ?
Re: What does YOUR timing gear look like? Having replaced timing gears on the road in the past I have put bronze timing gears with matching crank gears on all the cars.
Hmm, thats interesting. I've used the 'rag method' on just about everything. But, from the looks of that gear tooth it appears I'll be changing my ways. |
Re: What does YOUR timing gear look like? I too wondered why it was showing failure so soon. Other than manufacturing quality I had not thought about the rag. Purdy, I think you are on to something.
No, there was no noise. I know one thing for sure: I will only install metal gears from now on. Purdy, where would you get such a clamp |
Re: What does YOUR timing gear look like? Either Dan McEachern or George Miller posted a picture of the clamp in use. It is sort of a C clamp. The side timing cover is removed, the clamp , clamps on the cam gear and rests on the side of the engine so as to hold the gear in place for tightening. I don't have a picture of the clamp.
Re: What does YOUR timing gear look like? I guess this is just me, but my thoughts are a Fiber gear should not be condemned because of a Mechanic's poor craftsmanship!
