Richporter FD06?Is this a y-block dizzy? I was told by advance auto that the richporter FD06 was a replacement for a 64 f-100 292 y block,I ordered from amazon 68.00.Now i find out its also listed for a 302 sbf?Am i screwed?Will it fit the y block? it does have an O ring. thanks Mike
Re: Richporter FD06?Is this a y-block dizzy? Won't fit. Advasnce Auto shuld take it back, if their return policy is as good as NAPA.
YBlock distributors do not have an O ring. |
Re: Richporter FD06?Is this a y-block dizzy? Quote:
Mikhett, you say you got the distributor from Amazon? You should be able to return it no problem. |
Re: Richporter FD06?Is this a y-block dizzy? you can tell by the look of it if it fits a yblock.replacement ones did have an o ring.
Re: Richporter FD06?Is this a y-block dizzy? I think some of the confusion, regarding the Motorcraft distributors with the O ring anyway, is that they are late Service Replacement distributors as indicated by the part #C9ZF-12131-A. The C9 tells us it was manufactured in 1969, 5 years after the last Y's were installed in trucks. :eek:
Also, I have heard, and take this as an Ol' Dude tellin' ya, that the service distributors used a 289/302 body with a Y-Block shaft and gear. In fact if you do a search for the C9ZF-12131 part # it will tell you this is a 302 distributor. The A at the end indicates it's for a Y-Block. I think this is also the distributor that is recommended for Dura-Spark conversion for the Y-Block. Maybe GreenBird will chime in here because I'm not sure about the Dura-Spark conversion. Mikhett, Sorry about the detour on your thread. :eek: |
Re: Richporter FD06?Is this a y-block dizzy? Im sending it back thru Amazon.Iheard the shaft is too long.I found a cardone 30-2808 on Napa they have in stock 105.00 im ordering it friday.
Re: Richporter FD06?Is this a y-block dizzy? There are a couple on e-bay. Cardone 30-2808
Re: Richporter FD06?Is this a y-block dizzy? yes the o ring can be turned into a dura-spark I had one and did just to see if I could.easy job.
Re: Richporter FD06?Is this a y-block dizzy? You learn something new every day.
Re: Richporter FD06?Is this a y-block dizzy? When I converted my Yblock to Duraspark II I looked all over for a triangle body dist. All I got was dumb looks from the parts places. Guy at the junk yard at least tried to find one looking at the remaining Ford trucks in the yard but they all had the older type. Ended up taking the original shaft to a machine shop & showed him what I wanted done. Ended up costing about the same as a later rebuilt but everything worked out good.
Re: Richporter FD06?Is this a y-block dizzy? When you do this conversion with one of the Autolite Y-block distributors, it takes one fancy machine shop part and a Duraspark II donor. The upper rotor shaft of the Y distributor has to be turned down to remove the point cam and sized to suit the Duraspark reluctor / armature (8 bladed trigger rotor). The cam is hardened so I usually grind it off (carefully) before I give it to the machinist. The Y distributor is then assembled with the Duraspark stator plate instead of the old point plate over the modified upper rotor.
Send me a PM with return email address and I'll forward a PDF drawing file that details the modified part for your machinist to use. http://i73.photobucket.com/albums/i2...RotorShaft.jpg |
Re: Richporter FD06?Is this a y-block dizzy? To add to what Steve mentioned, I took the upper rotor shafts from both the Duraspark & yblock dist, along with the armature & just showed the machinist what I wanted. Got it back a couple days later just like I needed it. After it was assembled it looked like a 70's Duraspark dist.
When I picked up the donor dist. at the wrecking yard I also got the short wiring loom that goes between the ignition module & dist. Helps with wiring the new system up & looks better. Wiring diagrams can be found online & they're easy to read. I did away with the ignition resistor that bolts onto the intake manifold. In its place I installed a later model resistor wire under the dash. Again, it makes for a cleaner appearance under the hood. |
Re: Richporter FD06?Is this a y-block dizzy? The common Y block distributor - post '57 - is the Autolite, has the round grooved base and the internal flyweights like this photo ... slots in the older upper rotor control the advance.
http://i73.photobucket.com/albums/i2...erversion1.jpg The newer Motorcraft version has the triangular base described earlier - often used by rebuilders to make a more "modern" Y block distributor. That unit can be modified by replacing its point plate and upper rotor with parts from a '75 and up Duraspark unit. http://i73.photobucket.com/albums/i2..._ANDSLOT_1.jpg |
Re: Richporter FD06?Is this a y-block dizzy? I believe someone mentioned (earlier in the thread) - the need for a wiring schematic, especially when you are using the Duraspark in an older model vehicle.
http://i73.photobucket.com/albums/i2...II_pic_new.jpg This shows how the system is arranged - color coding etc. - and my preferred wiring set-up, which is to use a removable (plug-in) Bosch lighting relay to provide separate power to the coil and control box. As originally constructed, the '75 and up vehicles used a 1.4 OHM ballast resistor wire going to the coil - and full voltage was delivered to the control module. The N.O. lighting relays provide power on both output legs when energized - there are others so beware. The Duraspark had a specific coil and a snap on connector cap but other arrangements can be used. You don't have to connect the white wire to the starter solenoid for the system to work. But if you do - energizing the solenoid will then notify the Ford design controllers that starting is underway and it will retard the spark by about 6 degrees. A nice feature in cold climates. The system ground was routed by Ford back to the controller and grounded there to the fender. It caused some service problems and it is best that the distributor end of the arrangement has an engine block ground - as well as the black wire back to the controller. Ford design controllers use the same "dwell" to charge the coil as the single point distributor, and the coil resistance is limited to a minimum of about 1.5 OHMs. This basically limits the ignition system to the same performance as a basic single point ignition when running. Other controllers are adaptable - MSD - GM - MOPAR and once you have the trigger installed - a lot is possible. The life of the Ford/Motorcraft controllers has been an issue. It needs to be mounted in a cool convenient location - not adjacent to the exhaust manifold. You want easy access to the controller - and to graft the Ford plug ends into your wiring system - because their service life is spotty......some last forever - and some for a year or two. Carry a spare - they are cheap - and can be changed pretty easily with screwdriver in a few minutes. Serviceability can be maximized with a little forethought. |
Re: Richporter FD06?Is this a y-block dizzy? Good stuff, Steve. Thanks.
Re: Richporter FD06?Is this a y-block dizzy? Steve, you give the best explanation of this modification than any I have ever read, bar none. Thanks for sharing your knowledge and expertise in this subject. You are truly what these forums are about.
Thanks once again. |
