09A clutch/brake pedal assy vs 01A Will an 09A clutch/Brake assy work in place of a 01A? This will be going in a '38 presently with a '39 assembly.
Re: 09A clutch/brake pedal assy vs 01A what you are actually trying to do is be able to work the clutch with a lever instead of the slot end as on 40-48 Fords. change out the clutch shaft and run a 01A clutch pedal set
Re: 09A clutch/brake pedal assy vs 01A Quote:
Re: 09A clutch/brake pedal assy vs 01A Bracket to the frame and the brake pedal will work but the clutch arm will be offset wrong. Change it to a 40 ford pedal. The 40 clutch linkage when i did this had to be shortened and the ball that bolts to frame area was shaped alittle different then a 40 frame in that area. I did this in a 37 frame.
Re: 09A clutch/brake pedal assy vs 01A Top
Anybody know if the 09A '40 Mercury brake/clutch bracket will bolt to a '40 frame? |
