how do I adjust steering gear, '40 '40 ford, What is the procedure for adjusting the steering gear?
what kind of lubricant? thank you, fordman |
Re: how do I adjust steering gear, '40 need to get a copy of the service letter, that is the easiest way to learn how to do the adj,. I use a mixture of synthetic grease and sythetic gear lube-mix to the consistancy of mustard, also when I rebuild a box use two grease seals on the shaft, if you are only adjusting and refilling you might consider slipping an extra seal on the sector shaft
Re: how do I adjust steering gear, '40 6 Attachment(s)
Re: how do I adjust steering gear, '40 the original seals were leather...mine still had the original sector shaft seal with Ford script.. So I don't imagine the original lube was too thin.
I have heard you can just use moly grease like the later recirculating ball boxes. I figure a little leaking oil is normal for these old cars. I know why my dad had drip pans everywhere now. |
Re: how do I adjust steering gear, '40 Try restorationstuff.com Pennrite 1200W 500 ML LUB009 15.75 steering box lube, pg 12 in online catalog.
1-800-306-7008 to order. Paul in CT |
Re: how do I adjust steering gear, '40 Go to www.vanpeltsales.com
go to bottom of page and click on Ford Flathead V8 Homepage all sorts of info there for you. |
Re: how do I adjust steering gear, '40 thank you for the help.
fordman |
