'36 dist equip Q.. 2 Attachment(s)
Here's two pics of a dist that I've got. I'm trying to get correct dist/parts to have a rebuilder to setup for my '36 stock engine.
What year(s) will the pictured dist work on, and is it 'correct' for my '36 :confused: |
Re: '36 dist equip Q.. That is a little later dizzy. 37-41.
I believe there is actually 2 different coils for 36. Early 36 and late 36. http://img.auctiva.com/imgdata/3/6/5...1863143_tp.jpg http://i.ebayimg.com/t/1936-FORD-V-8...SEQ~~60_35.JPG |
Re: '36 dist equip Q.. Tinker X 2
Re: '36 dist equip Q.. Upper pic is 34-early 36. I have 2 of this type and 1 of the late 36 ones. Both are rebuilt usa parts,not sure if they have caps on them. No coils on either. $100 + ride / with caps $190 +ride all gaskets included. ken ct. PM. Id have to check them if have caps their boxed up for nxt show in April in camper.
Re: '36 dist equip Q.. not correct for the '36, but it should work, i think....you have the correct inner caps??....Mike
Re: '36 dist equip Q.. Oh it will work with the correct 37-41 inner caps,but sounds like he wants a 36 dist on it.. I have both styles of 36 if hes so inclined. Early or late 36. ken ct.
Re: '36 dist equip Q.. Quote:
Yeah, I have two 'inner' caps that are numbered starting with 68- ! So, it will work, but is there a better working model out of the three, i.e.- early '36;late '36 or the model that I've pictured ? BTW- I'm for the 'best' running equipment, just thot that I had to use original model. I also have a complete crab, but do not want to all extra hassle to use that right now(diff plate or diff cover,etc). |
Re: '36 dist equip Q.. There are adapter plates out there to go from the helmet(3bolt) to the crab(2bolt). But maybe that's what you meant about the dizzy plate.
Thanks for looking out for me:D Yeah, that's what I meant...you got that adaptor for sale:cool: |
Re: '36 dist equip Q.. 3 to 2 info. Although you mentioned you didn't want to hassle with the conversion. So this may be mute...
http://fordbarn.com/forum/showthread.php?t=65953 adapter sold here http://dickspadaro.com/ignition_adapters.htm |
Re: '36 dist equip Q.. Hey Tinker,
Thanks! A fordbarn bud tells me that he has the adaptor necessary to ease the hassle ! Hassle in my case , is knowing limits with current circumstances..not from lack of initiative! Young at heart...makes is not absolutely moot,eh! |
Re: '36 dist equip Q.. I think I helped then :confused:... was my only intention anyway.
Better on the road then not. |
