Model A Part's City:
San Pedro
State:
Ca
Price:
Varies
Hi Guy's Here's a list of some "A" Part's I have for sale,,, New "in the box" Chrome Luggage Rack with spare tire bracket's, fit's 28 to 31 $ 125.. 28-30 "oval" speedo,use as is, or as a core $30... Model A dial tire gauge,with leather pouch... $ 75... New "Ford" fender cover 3' X 2' Has large Ford script in the center. medium blue color $30 New dist drive gear fit's 28 to 34 $15.. (1) Steel brake drum heat ring $10.. (4) Generic metal valve stem's Has large cover's for the 28-29,,remove for the 30-31 $30.. Tilly Carb all there $35 Model A set of (3) main brg cap's $30.. Model A muffler, original type..I think made by Midas...New never used..I had it metal coated for rust $ 75.. 2 Tooth sector gear, good condition $15.. Left hand side tail bracket fit's 29 to 31 $5... Rebuilt A clutch disc solid center type never used $25.. N.O.S. Model A crank pulley..Has Ford script on rim $ 45.. New 2 piece"Rubber" Model B rear main seal $ 25.. Set of (4) new stainless 30-31 hub cap's never used, "show type" $60... New steering housing 2 tooth type with needle brg,,Has "O" ring seal. $60.. New Early 30 splash sheild "Nose piece" $20.. Set of 30-31 door handel's Chrome type,,,no key on the locking handel has # on lock cyl for key. $10 New rear spring's shackel's. US made in the bag $20.. Special front longer brake arm's (2) ,,from the old Ford Obsolete Same size as the rear $ 25... (1) N.O.S. Model A front brake arm $ 20 Rear window glass for 30-31 coupe or tudor Safey type $ 35...:) Please send all inquiries to me Direct at [email protected] Thanks Greg,,, |
