Dash Cluster Q's Hi guys - spent today tidying up the wiring which is in a terrible mess.
Previous owner has utilised a bit of old tat from his shed to mount the ign switch - starter button and light switch. I intend to improve on this as well as make the wiring safe. Any suggestions on where/how better I can mount these 3 parts oh & where would they have been originally please ??? Bob |
Re: Dash Cluster Q's Ignition switch is in the dash panel, mid-left side. Starter rod is on the floor, at least here in the Colonies. Might be different on RHD. Light switch should be in the middle of your steering wheel. What is "tat"?
Re: Dash Cluster Q's Tat is worthless stuff - scrap - rubbish.
Mine is a LHD from USA but is not as it should be the Previous owner has changed a lot of stuff - a lot. So if someone adds a switch for something ---say an electric gas pump -- where would you mount it ? Problem I am having is working round not screwing/drilling into the dash. Bob |
Re: Dash Cluster Q's Maybe ask on the HAMB, this site is for restored cars.
Bob |
Re: Dash Cluster Q's BobbyG, the original ignition was a Pop out type switch that had armored cable from the switch to the distributor for anti-theft purposes. The Starter was activated with a rod straight down to the motor on the floor above the gas pedal. So you would turn on the key and then hit the rod to crank it over. The lights were on a switch at the center of the steering wheel integral with the horn button. Sounds like much was changed with your car, and its Flathead V8, I like that you are trying to make it more period correct. Good Luck
Re: Dash Cluster Q's Quote:
Yes I appreciate that BUT I am asking where these things were mounted ORIGINALLY. If I wanted to know how best to drop a SBC in or chop the top I could understand your reply- and the HAMB would be the best place to ask. I am doing the best I can with what I have to hand & trying to keep an iconic American vehicle on the road in the Uk |
Bob |
Re: Dash Cluster Q's When I found my "A" someone had drilled the dash for a starter button and bolted a solenoid to the starter in place of the foot activated mechanical system. Got all of my parts from Bert's in Denver, Colorado modelastore.com.
Re: Dash Cluster Q's Further to the light switch, the contacts for the lights are mounted at the bottom of the steering column, this includes the contacts for the horn. There is a tube that runs up the middle of the steering shaft, with the horn button in the centre, and a bezel and lever that gets turned to turn the lights off/low/high. Original fit wiring looms are available, and already have the required terminals fitted. On my Tudor, the previous owner converted it to 12V, but really stuffed the wiring up. I ended up making a small panel which picks up the tank-cowl bolts inside the engine bay, and mounting several relays. On original RHD cars, the light switch contacts sit directly under the carb, which to me, could be a fire hazard if the carb floods.
Re: Dash Cluster Q's Since you have a V8, you may need to use a starter button, rather than the original foot push button. I would make a bracket that clamps to the steering column and mount any non-original switches or guages there. I also don't like to drill holes, weld, grind, or bend original metal.
Re: Dash Cluster Q's http://i118.photobucket.com/albums/o...berg/Test6.jpg
Your instrument panel should look like this. Pictured is a simple off-on switch I am using until I reinstall the original popout switch. With your V8 you can also use the same switch as I have in this picture. You should be able to use a stock wiring harness for the lights, and you can use the light switch at the bottom of the stock steering column, unless the steering needed to be changed for the V8. BTW, if you need a new instrument panel, try to find a good original because the bottom 2 screw holes don't line up on a repro panel. |
Nice. Well done. I got my Fordor with an alternator (incorrectly wired) and a downdraft carb that needed a fuel pump. The previous owner had drilled a hole in the dash cover for the switch so I left it there, but replaced it with one that looked period. I hid the alternator light up under the same cover so you couldnt see it but when it's lit the reflection is obvious. I also added a few fuses and I *know* that some will admonish me for that but, well, they can kiss my shorts.. so to speak :) oh ya, I got 2 original carbs with it but the 91-99 that's on it *really* runs nice so it's staying. |
Re: Dash Cluster Q's Thanks Chaps - it all helps - I think I need to try and mount something as Tom says out of the way but without interfering with Henry's design too much, thanks for the picture it was a great help.
