How do you know when springs needs to be rebuilt or replaced? I've noticed that my '31 Model A Fordor sits a bit lower (1-2 inches) than a few other cars (of the same year and model) I have seen and I wonder if this means my car's springs need to be rebuilt/fixed/replaced?
My car rides and handles great, but is there an easy way to determine if the front and rear springs have lost some of thier support? I recall someone indicating that for the front spring, the bumper-to-floor distance should be 18.5 inches, but is that from the floor to the bottom of the bumper? What should the (bumper-to-floor) measurement be for the rear spring? Thanks. |
Re: How do you know when springs needs to be rebuilt or replaced? one indication of a weak front spring is if the drag lnk is rubbing the tie rod assy.
Re: How do you know when springs needs to be rebuilt or replaced? I would look at the angle of your front shackles. As the spring weakens it sags and the bottom end of shackles rotates outward. I have seen the front spring so weak that the shackles are resting on the front axle. You should be able to put your finger between the spring eye & perch & have at least 1/8 to 1/4"under spring to the top of the axle.
