how to make doors fit tighter at bottom how to make doors fit tighter at bottom,top of doors touch top before bottom
Re: how to make doors fit tighter at bottom These doors are quite flexible as long as you are not dealing with the wooden substructure of some. Use your knee at the bottom of the door and pull the top of the window frame back a little at a time until you are happy with the fit.
Re: how to make doors fit tighter at bottom make sure the hinges are with no slop. even the least bit of looseness can give bad results...
Re: how to make doors fit tighter at bottom Since you have to "overbend" when you do that, consider removing the window glass. It doesn't bend and may prevent enough "twist" in the door. It also may break. This only works well for the steel framed doors. The wooden framed ones won't bend enough. Gar Williams
Re: how to make doors fit tighter at bottom Quote:
Re: how to make doors fit tighter at bottom Don't forget that many, if not all, Model A doors have a thick rubber bottom door seal that takes up quite a bit of room.
Re: how to make doors fit tighter at bottom ford31 .....................
If you have a two hinge door, you can make the bottom close a little bit "sooner", by slightly bending the hinge, inward. You can do this by placing an object, such as a hammer handle, into the hinge, and gently pushing the door closed, until it closes to your liking. Just don't over do it. It is, probably, actually twisting the door post. MIKE :) |
Re: how to make doors fit tighter at bottom A lot of careful twisting - and if your glass channels are 'tight', you may want to pull the glass - but make sure your hinges are tight and you have all the proper rubber bumpers in place, or you do it over, like I had to:o
Lot of patience |
