How to ID a 40-48 Lincoln Trans I have a Lincoln trans but need some help figuring out how to ID the year.
Thanks Z |
Re: How to ID a 40-48 Lincoln Trans Pretty much look the same thru those years. Compare the serial number stamped into the top (above the inspection window) to the serial # breakdown for those years.
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm |
Re: How to ID a 40-48 Lincoln Trans Serial number on transmission will start with an"H" from 1940 to 1946 , 7H for 1947 and 8H for 1948.
