Cleaning Aluminum Step Plates What is a good way/solution/polish for cleaning aluminum step plates?
Thanks - Hunter |
Re: Cleaning Aluminum Step Plates I removed them from running boards and used aluminum mag wheel cleaner.
Re: Cleaning Aluminum Step Plates Sorry - Talking about the square step plates for rumble seat..
Re: Cleaning Aluminum Step Plates Same thing. They are just aluminum.
Re: Cleaning Aluminum Step Plates Thanks TinCup. Any tips for cleaning between the small pyramids?
Re: Cleaning Aluminum Step Plates they make an acid wash for aluminum . when i was driving truck i had it done to keep things clean . works well with no side affects . try any local truck stop ........ steve
Re: Cleaning Aluminum Step Plates That's why I suggested mag wheel cleaner. Spray it on and then wash it off. Just make sure it's off the car.
Re: Cleaning Aluminum Step Plates I used the Mother's paste for mag wheels and put it on with a stiff toothbrush. I also removed it vigorously with a dry soft toothbrush ! Amazing results but remember they are not polished like running board step plates !!
Wayne |
