ID manifolds for 46-48 engine in 41 I think I have a later model flathead in my 41 Ford because it has the fan on the end of the crank. Can someone verify the year of my engine 46-48?
http://i371.photobucket.com/albums/o...psnzxszx4n.jpg Here are the manifolds. Can someone tell me what year manifolds they are? http://i371.photobucket.com/albums/o...psjuf297yb.jpg http://i371.photobucket.com/albums/o...psnuhcv0pe.jpg |
Re: ID manifolds for 46-48 engine in 41 There should be a casting part # on each manifold.
It's probably where you can't see it without using a mirror or "rubbing" it using pencil and paper. Get that number and you will know for sure. |
Re: ID manifolds for 46-48 engine in 41 Looks like a 59 series engine with 37-41 exhaust manifolds to me. 41s should have the fan on the crank.
Re: ID manifolds for 46-48 engine in 41 1 Attachment(s)
I agree. Could be a 1947 Ford engine like this one that was removed from a 41 Ford coupe last week. Post a photo of the distributor if possible.
Re: ID manifolds for 46-48 engine in 41 Also, note the CHANGED direction of the anti-chatter rods as seen in your pics, as well as in this pic, and Jim's pic. DD
https://www.fordbarn.com/forum/attach...9&d=1440604289 |
Re: ID manifolds for 46-48 engine in 41 V8, You got me thinking I may be wrong. Because of the anti chatter rods perhaps my photo is of a 1941 engine. It was removed from a 41 Ford with those chatter rods.
Did any other Ford engines use those forward facing chatter rods? |
Re: ID manifolds for 46-48 engine in 41 Seems I remember the '41-'47s (at least), and most-likely the '48s, too. DD
Re: ID manifolds for 46-48 engine in 41 Quote:
Re: ID manifolds for 46-48 engine in 41 That block is later than '41. The ports for the exhaust manifolds should be "extruded" about 1/4" on a '41 block.
