Stewart Warner speedo cable Need help with a source for a speedo drive cable from the '40 Ford torque tube gear housing to an early S/W speedo. The threads are different on the speedo & gear housing. Many thanks.
Re: Stewart Warner speedo cable Do you have the cable housing and nut that came with the S-W speedometer? If so, you can splice the speedo housing to a Ford housing with a piece of rubber hose and run the cable through it. Just a thought.
Re: Stewart Warner speedo cable Try A.C.I. Engineering, Inc. 6728 Lovers Lane, Portage, MI. 49002 (269) 327-1991.
