Water leaking around oil pan bolt on 59A Why is this water leaking around this oil pan bolt and how can I stop it?
http://i1059.photobucket.com/albums/...ps3ed6ffe4.jpg I just had to remove the oil pan to remove the fly wheel to get it resurfaced. Put it back on and now this water is coming out from under the bolt head. How can I seal it? |
Re: Water leaking around oil pan bolt on 59A This one has me baffled there is absolutely no water in that area. Are you sure the water hasn't been spilt or leaked from somewhere above there and ran down and puddled around the bolt head? The water jacket doesn't come that far back around the bellhousing.
Mart. |
Re: Water leaking around oil pan bolt on 59A I agree. It's probably leaking from a head stud or maybe the head gasket.
Re: Water leaking around oil pan bolt on 59A I wish you all were right. I had just removed the radiator hose on the head on that side and put it back on and thought maybe it was coming out of there and running down so I just wiped everything off and started the engine and watched it seep up around that bolt head.
Definitely a mystery. I guess I'll put some Permatex on the bolt threads and replace it and see if that stops it. Hope so. I'll let you know. If anyone else had any ideas please share them. Thanks for your help. |
Re: Water leaking around oil pan bolt on 59A As said before, there is no water in the bellhousing casting. If it's coming from there, you probably have a REALLY cracked block. It would need to migrate all the way along that bottom surface of the block and seep up the bolt threads. Many other places for it to seep out as well. Can you see leakage coming out the bottom bellhousing hole, the one with the big cotter pin? Any water in the oil?
Re: Water leaking around oil pan bolt on 59A Henry, you sure have a lot of problems.
Like the others have said, no way is the water coming from the pan bolt. Head gasket, head stud, or heater hose. |
Re: Water leaking around oil pan bolt on 59A You have such a close up picture that I am not sure what I am looking at. Is this a front or rear of the pan?
Re: Water leaking around oil pan bolt on 59A At the rear, just above the part of the pan that takes the starter. That's the transmission casing on the left. That's the bolt that was holding the pan on when it was initially being removed.
Mart. |
Re: Water leaking around oil pan bolt on 59A 1 Attachment(s)
Like here?
Hope it's not because of the grade 8 bolt:) |
Re: Water leaking around oil pan bolt on 59A Yeah, that's it. (except that one isn't even there!). You can see how water can't get there without being spilt or leaking from somewhere above and running into it.
Mart. |
Re: Water leaking around oil pan bolt on 59A Subscribed!! I have got to see how this one plays out. We need you on the road. I miss the pictures of your travels.
Walter |
Re: Water leaking around oil pan bolt on 59A Assuming the leak is not real slooow, why don't you remove that bolt (to slightly disrupt flow path), clean the area well by spray can, and just lie there with a good flashlight to observe what transpires?
Re: Water leaking around oil pan bolt on 59A I tried repeating my test (wiped everything off and ran the engine again) and no water came out. Didn't change anything. So, hopefully, false alarm. Time will tell. I'll watch closely under the car (I've replaced the floor) for the next few days for any water.
Sorry to bother everyone. |
Re: Water leaking around oil pan bolt on 59A Quote:
http://www.nps.gov/ciro/naturescienc...IMG_7246_1.jpg (This will be my 4th attempt. Hope we make it.) |
in that spot when it was new. :) |
Re: Water leaking around oil pan bolt on 59A Could it not be the frost plugs in the pan rail seeping,running back through the gasket and the flywheel spinning it out there? My 40 deluxe had a similar problem.
Re: Water leaking around oil pan bolt on 59A Frost plugs down there were not used after 1940 or thereabouts, so not an issue here.
Re: Water leaking around oil pan bolt on 59A Not familiar at all with a '48, but is the heater control valve right above there? Or the heater connections?
Re: Water leaking around oil pan bolt on 59A Ross, I bet you are correct.
Re: Water leaking around oil pan bolt on 59A Ah yes. A drip from above, not a seep from within.
Re: Water leaking around oil pan bolt on 59A You are right. I was picturing your first reply as meaning it came from above on the engine (hence my post after your's about leaky studs and gaskets). But now the idea that it dripped from the heater hoses seems even more probable to me. Sorry to not grasp your concept on the first go-round.
Re: Water leaking around oil pan bolt on 59A Water (and oil) loves to travel before it gathers enough to drip. You'd be surprised how far from the source a drip can emerge, even defying gravity. An don't forget how hard it is to dry off antifreeze spills. I use my air gun to blow it dry or at least blow it away.
Look at the wetness along the mating surfaces in the picture. It came from elsewhere. |
Re: Water leaking around oil pan bolt on 59A I may be old, but I can still recall the wetness along the mating surfaces.....
Re: Water leaking around oil pan bolt on 59A Mystery solved. Leak found. (Ross F-1 was right on.)
I was still getting water on the floor under that oil pan bolt. So, I removed the floor and that platform above the starter was loaded with water/anti-freeze. http://i1059.photobucket.com/albums/...psfa1e1c6f.jpg But, it didn't seem to have come from that oil pan bolt as I had originally supposed. So, I wiped and blew everything off and started the engine and watched. In no time the water was accumulating there again but did not seem to be coming from that bolt. But, I could see an itsy bitsy trickle coming down the bell housing. So, up to the engine compartment I went searching again on the intake manifold for any leakage from the radiator hose I just replaced. Nothing. Then I saw this drip. http://i1059.photobucket.com/albums/...psd7da3b69.jpg Coming from the end of the heater hose clamp bolt. In fact, you can see that the hose is almost pulled off of the heater pipe. That will have to be shoved back on, the clamp tightened, and we should be good to go for the road trip tomorrow.. Thanks for all of your help. It was, indeed, something from above. I just had to find it. |
Re: Water leaking around oil pan bolt on 59A Cool shot catching the drip like that.
Re: Water leaking around oil pan bolt on 59A While you're there you can get a bit of grease on that throttle ball and oil the throttle pedal pivot. Preventative maintenance is the key.
It looks like the hose could do with being a bit longer, hard to tell from the photo. Glad you found the source of the drip. Mart. |
Re: Water leaking around oil pan bolt on 59A Can't see the firewall hole in the picture, but it should be the same diameter as the heater hose. The correct installation has the hose going through the firewall with the clamp on the outside. This is per Ford specification due to vibration caused abrasion on the heater pipe, as well as the very thing that caused your leak.
Re: Water leaking around oil pan bolt on 59A I have the fresh air heater with the coil right against the firewall so the hose can't go through the firewall. Maybe into it a bit but not through it. It may well be a better approach for the next time I take it apart.
Re: Water leaking around oil pan bolt on 59A Where's your chatter rod for the right side?
Re: Water leaking around oil pan bolt on 59A Glad you found the source of your problem, professor. Now if I could be as lucky with finding out what is causing my backfire problem.
Your insulation on the inside of the firewall is half an inch thick. That's all you need. |
Re: Water leaking around oil pan bolt on 59A maybe I missed a post with an update, but how is the clutch chatter and the vibration?
01-12-2013, 12:12 AM #8 columbiA Senior Member Join Date: Nov 2011 Location: B.C. Canada Posts: 1,745 https://www.fordbarn.com/forum/images/icons/icon1.gif Re: Motor Stay Rods (anti-chatter rods) Anti-chatter rods 11A 6044 is used on 41-42 pass cars & 46-48 RHD cars.The 46 48 LHD cars did not use them.-From Ford of Canada 28-49 fast moving parts catalog. |
